Up & right during acceleration...
Tomcat
My 2006 GT (with 46,000) is starting to (ever so slightly) pull right as the nose comes up under acceleration...and comes back down to the left when I let off the gas (but not under braking as far as I can tell).
I am searching the forum BUT thought that some of the higher mileage members could point me to a likely culprit and potential remedy.
Ps-the alignment was checked and spot on.
Pps-Bridgestone tires and stock/original everything else (suspension-wise).
Thanks!
Simon
1,232
Rear tire pressure?
Tomcat
Rear tire pressure?
I will check...I normally keep 30 psi in the "stones".
Simon
1,232
let us know if they are uneven?
Reactions: twobjshelbys
jaxgt
2,795
I think i once had similar problem. Cant recall issue. Maybe something on rear suspension? I bet kendall or rich will know.
Reactions: reiner
Any shocks leaking? Wonder what the shocks would show on a shock dyno.....
Reactions: 2112
had a similar problem many years ago -internally broken ball joint in the left rear. This was not visible from the outside.
Reactions: 2112
Tomcat
Even at 30 psi per side.
Tomcat
Thanks all...looking for some way to test/inspect too.
Tomcat
How did you find/discover the break?
Slight yaw to one side on acceleration and to the other on deceleration strongly indicates the rear is out of alignment, or there are worn parts that allow the misalignment under the forces of acceleration and deceleration. Have you changed the rubber boots on the rear "tie rods"? How about the other joints with rubber boots that split and leak and allow dirt to get in?
Reactions: reiner and jaxgt
GT101
*UK Support*
381
Colchester, Essex, UK
I would be checking the rear tie rods for wear - movement in these ends will affect the rear toe.
jaxgt
2,795
Rear toe links were culprit for mine years ago
Tomcat
Alignment is checked/good...but all rubber is original. I will inspect for leaks/rips/tears.
Tomcat
I'm "feeling" tie rods...
Tomcat
Thanks found your previous post...do you know if they are available for replacement or did someone develop replacement "wear components"?
Ps-Go Duval :)
Tomcat
So, are we talking about:
Alignment Camber / Toe Lateral Link - Ford (4G7Z-5B551-A) same # left and right
or
Link-stabilizer bar Ford (4G7Z-5C486-RH and 4G7Z-5C487-LH )
GT101
*UK Support*
381
It's the Toe Lateral Link - Ford (4G7Z-5B551-A) - not sure on availability right now but we've certainly bought them in the past
Tomcat
Good afternoon, Thank you! Great community!
Reactions: GT101
I agree with my esteemed colleagues here. First, I would have checked the air pressures in the rear tires (which you did). Next, I would suspect the rear toe links. It may require more than a visual inspection, however, because I think the boots will look bad no matter what, but the link itself could still be ok.... These toe link boots on virtually ALL GT's we're seeing has disintegrated. It is the rubber that was used and really has nothing to do with how the car is driven... time just takes its toll. So, I'd bet money that the boots LOOK horrible on both sides... but it doesn't necessarily mean that the joint is compromised. I'd get the rear of the car in the air and then try to turn each rear tire and see if and slop can be felt, heard, or seen.
For new toe link boots, Dave (GT101) is your man. We will likely place a larger order for these soon so we can have some available here in the States.
Reactions: GT101
