hey guys- I know this is an old subject. have a friend who purchased a transaxle cooler kit from Ford Racing when they were available. he needs the instruction sheet if anyone might have a copy. thanks
There was one? I guess I don't remember. Pull the bypass hose off the top of the Ricardo, lines were self explanatory, riv nuts are in the frame for the cooler and lines, add a quart of trans-axle oil, done.
It's a bummer that the new Ford Performance site has eliminated all of the old Ford GT stuff. If you search the parts show up but none of the books. I'm glad I downloaded the ones I got.
Specracer: you have to remember that some of the owners are not as mechanically inclined as you and me and many others but thanks anyways.
twoshelbys: you da man!!! came thru perfectly! thanks too much
The problem with those instruction is it doesn't detail which is the supply and which is the return.. There is a small difference in cooling . Not near my car to tell you which is the correct orientaion
With the rigid tubing, wouldn't there only be one way (without crossing, which I don't think they do). If I get a chance later I'll go out and take pictures of the routing.
