Need an opinion? I have an elevated driveway, angled to the street. This requires that I place trailer ramps and 2/4s to clear the street and driveway so I don't scratch my GT. Have to put the car 90 degrees to the street and then check it to make sure I am lined up on the ramps. Accidently yesterday, I had set the car up, by the time I had done this I had people north and south of me waiting to see me drive the car up the driveway. I accidently started out in 3rd gear which seemed okay to start as there is enough torque to get across the semi level ramps, but once I started up the grade I started to lose clutch engagement. No noise, no clanking in the transaxle, just some smoke out the tire wells. I realized I was in 3rd, immediately downshifted to 1st and got up the hill. There was a fair amount of what I assume was smoke from the clutch, which quickly dissipated and the clutch works fine now and it worked fine then when I downsifted into 1st. Is there anything I need to be concerned with the clutch? It only lasted a second or so, when I realized what had happened by releasing the clutch from a slow start on a mild grade in third gear to a steeper grade. Shifting to first was no problem and grabbing the gears in 1st also no problem. Has me a little worried?
Your thoughts would be appreciated
