I ordered a complete set of Speed Hut gauges today and need a bit of information and photos to finalize the order. The issue has to do with having the voltage gauge customized to show actual voltage values rather than non-numeric index marks. Since my voltage gauge has failed, I cannot do this myself.
I'm hoping someone will assist me by measuring the actual voltage (using a seperate voltage gauge) and taking a photo of the voltage gauge with the ignition on (but engine not running), and then measure the voltage again and take a second photo of the voltage gauge only this time with the engine running.
The data and photos will be used to establish the relationship between the pointer location and actual voltage. As the gauge is linear, interpolation and extrapolation will be used to establish the full range of numerical values. As others on this forum have expressed the desire for specific indexing, this effort will facilitate the availability of a numerically indexed gauge.
Thanks in advance for your assistance. With three failed gauges (and probably more on the way), I will be so thrilled to finally put this failed gauge issue behind me.
