replacement battery
zach05855
222
Calgary, Alberta
before someone bites my head off. I need to replace my battery. I was trying to find a recent post about replacement batteries and the general opinion, but they all seem to be several years old.
Sears no longer sells batteries in Canada, Optimum batteries seem to have differing opinions on the forum.
I would appreciate to hear what today's ideas are regarding batteries?++
All set
I finally found the post with battery recommendations
Not sure if you smog in Canada, but changing your battery, messed up the US smog testing to the point that you fail to pass. Takes about 120 miles of driving between 65-70 to reset the smog mechanics to eventually pass.
33Bravo
688
Minneapolis, MN
I believe the highly recommended Die Hards are no longer sold by Sears. I also think if you hook up 12V to the cigarette lighter (ok, Power Point) when you are changing the battery, you can preserve internal settings and not have to worry about smog settings as the result of the battery change.
I'm interested in what becomes the next "go to" battery.
Odyssey
zach05855
222
Calgary, Alberta
This is what I use to protect the memory on the electronics. Just plug into OBDii connector.
http://cloreinfo.com/solar-esa30-obdii-memory-saver-connector/
My FGT is the only vehicle in my small fleet that I don't use one.....yet.
This is a cool tool, Easier than the jump pack on the battery leads, that I have done with other cars where there was space.
junior
1,151
So Cal
What type/brand "jump starter" are you using to plug in the non OBDII connector ?
zach05855
222
Calgary, Alberta
junior
1,151
So Cal
:thumbsup
MTV8
1,018
A lithium battery may also be worth looking into.
Just bought one, a whopping $13.50 off amazon.
TO AWSUM
Ford GT Owner
1,506
Niceville FL
Zach,
Here's the battery I used, Deca AGM 9A35/85. The stock battery posts are very close to the front sheet metal framing. Reversing the battery posts and moving them away from under the framing made it a lot easier to connect the battery and ensure it doesn't ground out on the front metal framing. This battery works great and has the safety benefit of keeping it from arcing against the frame and causing a fire if you have a front end collision.
Picture here. http://www.fordgtforum.com/forums/showthread.php/29532-Battery-Tribulations?highlight=
Jer
Howard
1,137
Florida/North Jersey
If you're in the battery area anyway, you may want to add another ground cable, as I did, to help guard against a loss of adequate ground.
Howard
nautoncall
1,093
Howard
I would second this. I lost power at a gas station one night and didn't know what was going on. I had to get a tow home just to figure out bad ground!!!
Howard
1,137
Here are some photos. I used an existing threaded chassis hole near the battery. I decided to do this after I got stuck, despite having cleaned the chassis ground in accordance with Forum recommendations. No problems since. And, for what it's worth, all my gauges still work.
Howard
BIGFOOT
739
Northeast
Great idea on the xtra ground.
junior
1,151
So Cal
What size bolt to secure the second ground strap ?
Howard
1,137
I don't remember.
Howard
33Bravo
688
Minneapolis, MN
I see a number of options keeping the electric system "alive" via the OBD port. Whereas I'm sure this works great - wouldn't just supplying power to the power point (cig lighter port) be easier (thats what I did)....
