- Oct 15, 2014
- 16
Hi Guys
For a while now we have been experiencing accelerating power problems from slight to very bad performance (7pm range from 2,000rpm up to 5500 rpm (slow building and not smooth). We have replaced the obvious things like spark plugs, coils, injectors, fuel pumps, filters of course engine oil. Which each area of the car we replace there is some improvement. But the problem still is present but not as bad as it was first.
The boost gauge is reading correctly and there appears to be no air leaks in the system.
The power problem is at its most noticeable when cruising wanting to speed up dropping a gear or two and pressing the gas pedal down fairly quickly to accelerate.
If you do a standing start to low speed lower gears the performance is bareable. If you operate the gas pedal gradually the performance is smoother but still signs of hesitance.
I'm thinking waste gaste? Anyone experienced similar problems?
