popping out of gear
Outlaw
81
Jacksonville, FL
GT has about 1700mi on it and it pops out of fourth gear. Only fourth.
It started out only doing it sometimes under accelleration, but its gotten worse to the point that I have to hold it in 4th with my hand to keep it from popping out all the time.
I did a search and found a lot of info about the second gear crunch , which is NOT the problem.
I also found a thread where eshrink's car was doing the same thing, but nothing was ever posted as to what the problem was or the fix ...
any ideas before we tear into this thing ?
usmcfred
546
Massachusetts
Popping out of gear can be caused by shift linkage requiring adjustment or a bad syncro. As your GT is still under its 3 year/36,000 mile warranty, take it into the Ford dealer of your choice and let them diagnose and repair it at no cost to you.
freeflyer
GT Owner/ Forum Sponsor
180
Montana
Check the folowing according to the manual.
Transmission jumps out of gear
Loose powertrain/drivetrain mounting bolts.
TIGHTEN the powertrain/drivetrain mounting bolts to specification.
Pilot bearing.
INSTALL a new pilot bearing.
Internal component damage or wear.
Transmission internal concern. INSTALL a new transmission as necessary.
Gear teeth worn or damaged.
Neilda
3,559
The manual doesn't appear too helpful - I've looked through it a few times.
Wife not pandering to your ever whim - install new wife
Too much debt in your life - install new funds
Children too noisy - install new children units
Life somehow unsatisfying - get new life
It's a bit like reading the Star Trek How to be Borg hand-book.
Instead of "Internal component damage or wear - Transmission internal concern. INSTALL a new transmission as necessary" the English version would have:
"Internal component damage or wear - ooh, that does sound nasty. Could be any number of things - when was the last time you checked your oil?"
Outlaw, sounds like linkage adjustment to me.
