Panel screw placement during oil change
Magic
742
Fredericksburg, TX
Today I did an oil change on my '19 NFGT. The CFunder panel you remove to do the oil change has 36 screws that need to be removed. I remember hearing somewhere that the screws are not the same size so I decided to keep track of what screw came out of what panel hole locate.
I've got the official Ford repair manual/CD and they have an illustration showing the location of the screws, but no mention of different screw sizes. I printed out the picture and labeled each screw hole with a number. Then as I removed each one I used a piece of cardboard with holes to place each screw into the corresponding panel location number. It appears that Ford used two different size screws to attach the panel. I called them L (large) and S (small) and marked the cardboard holder with hole numbers and size (L,S) designation.
Call me compulsive, but I wanted to make sure and get the right size screw back where Ford had designed it to be.
Attached is a picture of the screws in the cardboard, the panel illustration with hole numbers and finally a close up of the two screws side by side.
Hope this maybe helps out if you are going to do your own oil changes.
Interesting fact that when I first got the car, hole location #1 was missing a screw. Dealer did the first oil change and didn't mention that a screw was missing nor did they source one to replace it. Guess a $1300 oil change doesn't warrant a $2 screw replacement. Just saying!!
Thanks for the chart. We had a similar issue with the pans on our Lotus, once we had long short figured, we would put a paint dot on the head and on the pan, different color for each length. I will use this as a template. (y)
Reactions: FerrariSlayer
Your problem is obvious - You need to work clockwise.
Reactions: JWZ
spartan
1,220
Bloomfield Hills MI
This is great. Appreciate you doing this.
Simon
1,232
I wonder is if this pattern is consistent for all the cars.
Magic
742
Fredericksburg, TX
I wondered about the placement since I had the dealer do the first oil change (actually 2 -see previous posting), but there does seem to be a pattern that they put them back in and not just randomly inserted screws. So I assume all NFGT cars follow this.
Magic
742
Fredericksburg, TX
I'm retired so I don't have to do anything by the clock!
steved57
1,941
kilgore tx
Haha good work Gary !!
texas mongrel
1,662
I had missing screws too.
In my Last oil & filter change (which was not done by the same mechanic) there were 2 missing screws from the center panel and he noticed other screws 4 missing in other panels also. His comment was that when your car comes back from being worked on put it up on a lift and check for missing screws because some mechanics are not putting them in a safe place and they are lost or swep up by cleanup people at night! BEWARE!!
Room for plenty of jokes about loose and missing screws with you guys.
Reactions: BtwoG and steved57
Gene Cassone
1,003
way upstate NY
If the screws are being lost and not replaced does not give me allot of confidence in the dealer! I noticed screws were missing on my focus RS after dealer service. I would not expect the same for the GT! Another reason to do it myself ( like my 05 GT!).
Reactions: steved57
68Rcodeman
800
Spring Hill, FL.
A real good mechanic knows which screws weren't really needed.
Reactions: Special K
texas mongrel
1,662
My screws were missing from Markham. The “hand-built” category is not always a good thing!
