oil pressure sending unit
standj
GT OWNER
755
Wyoming
Can the oil pressure sending unit be replaced without dropping the belly pans?
John
John
Hi John
On my gal with headers the answer is yes however sadly I cannot confirm on a gal with OEM manifolds.
My guts tells me; yes even if you have to be a bit flexible; as with your tools too
All the best
analogdesigner
949
San Clemente, CA USA
9 ft/lbs upon replacement
Hi John
All the best
Well, Shadowman is correct on this. It's really tough though. I just did mine from the bottom, with the pans removed. Removing the electrical connector can be tricky if you are not familiar with Fords (I wasn't). It wants to be torqued to 9 ft/lbs upon replacement.
Good luck on this one,
Jay
GTsaver
tpraceman
THEE GT OWNER
2,835
Washington Michigan
Can I ask why you guys are changing sensors?
analogdesigner
949
tpraceman,
They are probably experiencing erratic readings on the oil pressure gauge. Mine did that on the way home from the dealer.
Here is post that started it all: http://www.fordgtforum.com/forums/showthread.php?t=409
Jay
GTsaver
JOEA2
352
STATEN ISLAND,NY/SEA GIRT,NJ
I've had the problem since new, about two weeks ago. They odrered a new switch for me. It should be installed next week. I was also getting the "check gauge" light and a beep.
standj
GT OWNER
755
Wyoming
Thanks folks, sounds like I will wait until the next oil change to change out the sensor!!!
Thanks again
John
