Oh great tech gurus....I have a question regarding the orientation of the 2 seals between the oil pan and the oil pump. These 2 seals (one a rectangle, the other looks like 2 sqares side by side) have what appears to be a top and bottom side to them. There is a single ridge on one side and a double ridge on the other side. Which side is oriented towards the oil pump? When I look at the main oil pan seal, it is asymmetric. There is only one way to install it...with the single ridge side up towards the block. It sits in a trough in the oil pan itself. Is the orientation of the oil pan to pump seals the same?
I had a leak between the pump and oil pan and have pulled my oil pan to fix the problem. The old oil pan to pump seals were both oriented with the double ridge towards the flat mating surface of the oil pump. Makes me wonder if they were upside down. Thanks, AC
