oil gauge
JimmyK
42
Lafayette, California
Hi Guys, My oil gauge stopped working/ frozen at 65. I only have 450 miles on the car. Ford wants $850.00 just for the gauge. Does anyone know where I might find a new or recondition oil gauge cheaper than 850? Thanks much. Jimmy K
I think you should do a search. It is probably the oil pressure sending unit and not the gauge. There are several old posts here concering this and it's MUCH cheaper. Contact Torrie for parts.
tmcphail
GT Owner/Vendor
4,102
St Augustine, Florida
I can get one new if needed :
Part Number 4G7Z9273AA
Part Name INDICATOR ASY - OIL
MSRP $814.70
Core $0.00
Online Price $684.3
Kayvan
4,782
Check ur battery too
tmcphail
GT Owner/Vendor
4,102
And if only the sender is needed :
Part Number 4G7Z9D290AB
Part Name SDR ASY-OIL PRESS
MSRP $51.84
Core $0.00
Online Price $36.29
...and the ground for same. For some reason many gauge pblms have be solved just by cleaning that whether it looks corroded or not.
AMB
401
San Diego,Ca.
JimmyK
I have a good used oil gauge, that I will sell you for $375 + S/H if you need one.
JimmyK
42
Torrie, Thanks much. How do I find out if it is the oil gauge or the sending unit?
tmcphail
GT Owner/Vendor
4,102
I would unplug it from the harness to see if that has any net effect on the problem.
JimmyK
42
Thanks Empty. Will check out ground
JimmyK
42
Thanks Torrie and all other members that responded. This group is truly educated and helpful with GTs
