Glenn,
I'm assuming that one of the reasons that you have posted two threads about this problem is that you are interested in getting some feedback and help.
That said, based on reading both threads, there's nothing to me that suggests that there *IS* a problem at all. Please understand that I'm just trying to help and I know you're going through all of this trouble to swap blowers, etc., but I still don't understand the *problem*.
It seems that you are chasing a symptom where boost pressure tails off a little bit (2-3psi) at the upper rpms. First point, I'm not even convinced that this would be abnormal and could be the fault of the way you are measuring. Do you have ANY evidence that your GT is different than anyone elses? This could be accomplished by getting another GT and hooking it up the same way you are today for measurement. If you ask me to bet between a fault in the GT compared to the method used to measure.... I'd be looking at your measurement.
To further the point, it seems you are looking for a physical escape route for the boost pressure (bad gasket, crack, etc.). First, I think the odds are low (haven't heard of that problem in any other GTs) and second, a physical one-way leak is really unlikely. (I believe that if you had a leak under vacuum you'd know by now due to irratic idling conditions if nothing else.)
I offer this constructively - and again with the assumption that you are seeking help from the forum. If true, can you please tell us more about the symptoms and what, if any, evidence that you have that the symptoms are unique??
Best regards.
