Good tips on preventive methods.
I had trouble with muffler mounting system nuts and bolts - not badly marred, but not perfect either.
Decided return to perfection would only come with new hardware, and the tape trick and extra care on assembly.
Ordered parts from Ford. Net prices were like $3 and $4 a piece! Yipes! Thought the high price was because of the plating. Not so, parts that came were not plated. Also, due to error in parts diagram, there was a mis-match between the bolt ( 13mm hex ) and the nuts (15mm). The nuts were actually the nuts that go on the clamps between stock muffler and cats.
Anyway, just trying to make the point that replacement parts - at least fasteners - may not be up to what you would expect.
I sent them back, figuring for that kind of money I could go with all Stainless and not have to deal with plating. If you're careful with the stainless you shouldn't have marks, and if you get minor marks, I think you could polish them out.
Much as I want the car to remain original and perfect, I have to face the reality that if you drive it or work on it, there are going to be marks. I guess you just have to be as careful as possible in both driving and working.
