Magnetic battery charger
have this on some of the other cars, it is a great way to connect the charger to your car and if you should forget and drive off it simply disconnects without tearing anything apart. also no more opening the back every time you want to connect the charger for 2019 cars and or opening the front with earlier cars.
I found what I suspect would be the cheapest panel on the new gt to put a hole in for the connector. The base attaches near the battery, I chose the front inner wheel liner its thin flexible plastic and it comes out with some plastic push pins. the battery is right on the other side of it under the pass side headlight. two wires to connect and I had to modify the charger cable by cutting off the battery clamps and wire in the new magnetic pigtail.
Very clean solution Soroush.
Reactions: soroush
Like that. A solution to a problem I didn't know I had
About the only non CF piece on the car...
Reactions: soroush
canibl
445
Sacramento, Cali
well done!
Reactions: soroush
Kinda like the magnetic charger attachment on older Apple laptops. Good idea. Is the magnetic coupling in that thicker black part about 6" down the pigtail or is it at the port on the fender liner?
Quite nice!
Reactions: soroush
its at the port on the fender liner
some ferraris and mercedes use this as oem equipment you can see on the back of the ferrari how it is attached however I was not about to poke a hole in the back of my car :)
nice idea!
jr66
272
scottsdale
What is the manufacturer of the magnetic connector.
I think the company is called Magcode
i even installed one on my old truck
Reminds me of the 80's alarms when they drilled the key cylinder into the drivers left front fender...
BAT
946
Central Mitten
I thought I was the only idiot to drive off without disconnecting. Whew!
zach05855
222
Calgary, Alberta
MagCodePowerSystems 12/24 V
https://www.rosenberger.com/0_documents/de/catalogs/ba_automotive/MagCode_Flyer_2010.pdf
I ordered mine from the UK, the US distributor has not been able to supply.
Reactions: soroush
GTdrummer
2,104
Richmond Virginia
It’s on the 488 and should be on all cars.
Reactions: soroush
jr66
272
scottsdale
Thank you for the information
right! I remember those, however in this case I wasnt worried about ruining the lines of the truck :)
on the 93 cobra, the 69 boss, and the c4 vette I stuck them all in the fender liner works well there, i might drill a hole in the side of the Lincoln I haven't decided yet... I still have a few more to do, I made a bracket for the boss and used existing hardware to attach it no drilling anywhere. I may do the same thing with the 71 camaro and still deciding where to put the one on the 05 gt probably in the plastic spoiler in the front near the battery somewhere, as gt drummer said every car should have one.
we have all been there...
Reactions: THamonGT
You are not alone on that one! I couldn’t believe I had done it! But the bigger question is did you admit that to your wife?!
I almost ran over my charger yesterday after bringing my GT home from a show! Missed it by 1/2 inch dragging it! Damn!
DG1
82
Toronto
I just added one of these to the 05 today! Excellent idea! Thank you soroush.
Reactions: 2112
