Looking inside an engine during cold start (-30 degrees)
Brombear
1,396
Frankfurt Area, Germany
Recently found on youtube. See what happens (transparent oil sump and rocker panel)
DakotaGT
1,697
Sioux Falls, South Dakota
Yikes!! Interesting video. Glad my garage is heated. Thanks for posting!
Reactions: ByeEnzo
Thanks. Interesting.
TO AWSUM
Ford GT Owner
1,506
Niceville FL
Yes, interesting, but I wonder instead of using his mineral oil at his -30C (-22F), how the new synthetic 5-50 oils would have done or even 5 weight oil. I used 5 weight dinosaur oil in Colorado with my Toyota 22R engine sitting outside all night at -40F and it started and ran well.
Reactions: steved57
Thank you for posting, comrade 😂
Dr. Frank could translate for us also.
Good use for an old Lada in this experiment.
Good pick up on the Lada, tovarish
Reactions: ByeEnzo
They make zero weight synthetic.
Brombear
1,396
You can add suggestions to the video, maybe they will post a new video (I am still freezing)
TO AWSUM
Ford GT Owner
1,506
Niceville FL
If you were responding to my statement about the 5-50 synthetic, I think you missed my point. It appears he tested a much thicker "mineral oil" solution than most USA cars run these days, so the test isn't really valid to USA cars. The mineral oil may solidify at a much higher temperature than modern synthetics.
I didn't miss your point, I was agreeing and adding that even lower viscosity oil is available.
I think the video was like many Youtube videos. Constructed for entertainment first.
