I am curious about owners that have had their hose clamps fail on their cars. Has it been mainly the same clamp that fails? Also, are you just replacing them with a normal hose clamp or something special?
....a shadowy figure told me about breeze clamps...
http://www.normagroup.com/kunden/norma/ttw.nsf/id/EN_Breeze
I don't think the reported hose clamp issues were failures. If I recall the clamps came off because they were never tightened properly from the factory
Never had an outright failure, but a couple of years ago, I spotted some coolant leakage when I would get home, at high altitude (8,000 ft) where the external ambient pressure was lower. The next time I had the car serviced, they did a complete pressure test and found small leaks at quite a few hose connections. We replaced all the hose clamps with good wide stainless clamps, and we put in the Accufab hose springs that prevent hose collapse (because the water pump is so efficient). Never had a problem since.
