Most GPS/radio headunit need a speed pulse signal input. Most, if not all of the owners on this forum has used either the Alpina or Pioneer speed pulse generator that reads the rotation of a magnetized tire. Those that tried to use the VSS signal from the transaxle haven't had much luck. The VSS signal is a reluctance sensor that usually generates a sine wave of varying voltage (0-3v) and frequency (proportional to speed). I guess the headunits are expecting a cleaner signal, something like a varying frequency square wave at 0-5v or 0-12v.
My question is does anyone know the electrical specs or the speed input signal. i.e. voltage levels, and frequency range? The reason I am asking is I have a system I am going to install and spec would make it easier to decide if I should buy another "black" box or make one.
It would be relatively simple tap the VSS signal as input into a opt amp comparator to get a square wave and divide it down if the frequency is to great.
