Girlie Man Clamshell Gas Springs
usmcfred
546
Massachusetts
When the car and ambient temp is cold, the gas springs seem to not have enough opening tension to keep the lid open far enough to keep the safety latch from re-engaging while I disengage the latch on the other side. This is not an issue when the car is warm after driving.
Would new (Ford or other) gas springs solve the problem, or is this just the nature of the beast ... ie, the gas spring opening tension spec'd by Ford is inadequate when cold?
Thanks, usmcfred
jrader1
41
Have two GTs. One has had no problem, the other did exactly what you described. I had the mechanic put two new shocks on the one with the problem and now it works great. Trick to handle it for now is to slip a small soft towel on the one side when you open the clamshell to give you time to walk to the other side to open other latch.
i think there is an easy fix, there is some sort of pop up bump stop that replaces the rubber stop on the driver side everytime you pull the hatch it pops up and keeps the clam shell up, try shadowman I believe he can help you.
usmcfred
546
Massachusetts
Thanks for the replies ...
jrader1 ... the "towel method" is what I do now ... but it is an ass pain. Looks like getting a replacement pair of gas springs (under warranty) is the way to go.
soroush ... I have the later "spring" type bump stops, however they only are meant to provide a gap wide enough for you to get a finger on to the safety latch to disengage it. The gas springs do the heavy lifting.
05redrich
136
With the door open wide, I find I can do both latches from one side of the car by
leaning into the roof opening left by the door.
oh I had no idea, I thought they would provide enough lift and hold the clamshell open past the latch so that you could walk to the other side and disengage the other latch. how bout if you open the spring some? i thought of getting the spring just havent got around to it, I can think of 10 other things at anytime that I have to do to the car, so for now, its the rag method for me.
Waxer
927
I use the little rag trick mentioned above and sometime the lid stays open on its own if I let the drivers side down real gentle like.
+ 1
timcantwell
2,634
N.E. OH & Naples, FL
That's exactly how I do it, not a bad reach with the door open!
With this method, I try to remind myself to look out for the watch and other bad accoutrements.
4,211
I've ^@$#$&* scratched the roof once and only once.... nothing that a Porta wouldn't take out though. MUCH more careful now to the point if I'm in the car - who needs a watch :thumbsup and if I pop the hatch - lean way it the door and wallah - no problem!
Your gut's not in the way? Who are you kidding.
FlorIdaho Chris
Yeah, I've got one.
OUCH!
I have the same 'cold strut issue". Can't open my door wide enough to get to both side latches when in my garage parking space. I will try the 'rolled towel' approach.
sr71
514
Calgary, Great White
My short little arms and jacket zippers, belt buckles, etc made it necessary to do the walk around as a matter of non-scratch safety. After a couple of times when the opposite side would drop back into the catch mode, I made a mod. I got some little rectangular joiner plates from Home Depot and spaced the passenger side latch about 3/8 of an inch longer. painted black they are not noticable, but allow the driver side release, then passenger side release, without the relatching on the drivers side.
S592R
2,800
I'm + 2 or 3 (whichever) on the lean over drill. Just don't wear your watch and you won't scratch the car.
Neilda
3,559
My GT is the same - i.e. when the engine's cold, it won't hold. So I always slip my left shoe off and stand on the drivers seat.
Obviously if you're wearing thigh length lace up latex boots, then it's not so easy. But I think only Geirkink has this issue.
:biggrin
sr71
514
And the navel stud scratching the roof edge is just one more reason to play safe and do the walk around!
ViperJoe
1,305
Washington Crossing, PA
Does anyone have a part number for the spring assists?
You didn't have to share that visual...:frown :lol
