Car was stalling on engine start intermittently so after reading through the forum decided it was the fuel filler flap. When I look in the fuel fill area the flap has definitely fallen off so that is one problem that will need to be fixed.
Then I had the error code checked and was thinking it would be the EVAP code but it was P2196 O2 Sensor Stuck. I have done some reading but still am unsure if I should have the O2 sensor replaced or not? Do you think it could be related to the flapper issue or maybe some other issue? Any advice is appreciated, thanks guys! :thumbsup
