Engine Oil Drain
1931imperial
27
Has anybody engineered an oil drain arrangement to eliminate dropping belly pan?
Thanks,
Ron
ViperJoe
1,305
Washington Crossing, PA
Nope and BTW there are two drain plugs in pan and one in the oil tank.
GT Tech
Ford GT Team Alumni
Aug 13, 2006
678
Kingman, Arizona
Ron,
Actually, pulling the pans to change the oil is a good thing. It gives you a chance to eyeball the drive line for any issues that may arise. (hose clamps, tie straps in place, leaks, ect.) Just use a good flashlight, and look everything over good. Many things can't be seen from the top.
If you pm me, I'll give you my number. Then if you see anything questionable, you can call.
Rich :thumbsup
barondw
1,109
Create an access panel in the belly pan.
usmcfred
546
Massachusetts
Any cutting or modification of the belly pans will possibly affect the under-car aerodynamics and thereby, the ground effects as well. I would leave it alone and just remove the bolts when periodic service is required. As a previous post said, it's also a good time to inspect everything visible for wear, looseness, leaks, etc before a major problem results. usmcfred
barondw
1,109
It won't negatively impact anything. I already have access ports and track the car so I am speaking from real-world experience not supposition.
Dave
cobrar1339
956
Diamond Bar, Ca
When you get a chance could you post up some pics of your modified pan. I would imagine this could come in handy at the track.
