Does the BOOST GAUGE need calibrated after replacement?
My boost gauge died last fall. I found a couple of used ones. I finally got some time to replace it. The first replacement gauge did not work either so I got to pull the dash array again and try the other used one. This one works but I don't think the reading is right. The needle zeros out with ignition but at startup it shifts to 20 mmHg negative boost. I can't drive it to check its response because Iowa is still having winter but upon warm up hitting the throttle will drive the needle up to zero or a little better. Is this gauge bad too or can it be calibrated? I have disconnected the battery a couple of times to see if it would reset but no luck. All other gauges work perfectly. Sorry so wordy.....any ideas would be greatly appreciated. :confused
