Dead battery-- easy fix 2020 NFGT
Mar 28, 2019
24
2020 Ford GT dead battery / charging battery when doors wont open.
I was travelling for several weeks, battery was dead, and I couldnt unlock car or open doors. I search threads on this forum and found all sorts complicated suggestions (take FR wheel off ). Leave windows down 1/2" so you can open doors, etc.. The solution was actually very easy.
1. Take valet key (real metal key that's inside the FOB) and use key hole under right side rear bumper. This opens the rear truck lid.
2. Use FORD GT battery tender by connecting it to the charging port (cigarette lighter port) in the trunk. (The battery tender will not work until you hold down the reset button on the tender for 10 seconds).
3. 10 min of charging later, the car opened and started.
GTMD
957
Awesome! Almost sounds too easy ;)
Mar 28, 2019
24
It was. At first I read threads about get a special jack to lift car, remove front wheel, remove wheel lining to access battery. Others said they broke door window because window wouldnt go down...
Yes. Sometimes that process has failed to wake the car.
Simon
1,232
Dave
Is this why they upgraded the charger to higher amperage?
....And also the early cars (2017 and maybe even 2018 - I don’t recall) DO NOT HAVE A CHARGE PORT IN THE ENGINE COMPARTMENT.
You must open the hood to the battery.
SO , ON MY 2017 H0098, Joe Sicoli at Milliken installed a charging port in the engine compartment for me! Just like newer models.
Ajb (andy)
Simon
1,232
Ajb (andy)
Can you post a picture?
italianjoe
182
Dearborn Heights Mi.
Hello Simon,
If you would like I can text you a picture?
Joe
Reactions: Simon
Joe, thanks, please post picture...
It is ok to use my vehicle if you have a pic of it.
Andy(ajb)
You can see the pigtail red/black wire connected to the terminals on the smart junction box top left. Makes it easy to connect the trickle charger on the early cars. If voltage drops enough, the cars battery goes to “sleep”. It has to be “bumped up” directly, bypassing the box. A newer, higher amp charger is used now vs the earlier cars.
I upgraded to one.
On my Mk II, there is a direct port that bypasses the box. I keep a charger directly connected to it.
Are you running your charging cord from under the front hood over the front passenger tire? I'm currently doing that (Steve showed me how) so I can close the hood and still have it connected easily.
Syco, you have a charger port in your back trunk with 12V plug. If you want to continue using the front trunk points, ctek makes a pigtail with ring ends to directly bolt on and you no longer need the alligator clips. Bye Enzo has a pic here. It comes fused or infused and costs $8-10.
Reactions: SYCO GT
Thanks Doc!
I decided to use the front hood since I can fully close it will I wait for the paint to cure and take some photos. I wasn't aware of the Ctek pigtail with ring ends, and I actually use Ctek chargers, so I will take a look, as I might already have one somewhere, thanks for mentioning that.
I did not hook up to the back trunk port, but when you do, you have to leave the engine cover cracked open a bit, right?
I'll likely transition in any event to that method after I get the wrap completed.
My '18 does not have a rear charger port.
Don't forget the windshield skin.
Yes, planning on windshield protective skin and possibly a double layer of expel on the lower doors, did you single or double that area?
Under doors 2 layers. Also 2 layers where aero tunnel exits onto the lower part of doors.
Whole front 2 layers. Bottoms of doors two layers. Fenders behind wheel wells 2 layers. Fender/door tunnels 2 layers. I did not have side mirrors pulled. Windshield skin done by window tint guy, not clear bra guys. There is no tint in the Windows so I had a relatively clear tint done on side windows. I think it cut out 20% of uv . It helps with heat in the summer, but I may go darker.
Reactions: SYCO GT
fordgt6
123
East Lake Weir, FL
fordgt6
123
East Lake Weir, FL
I did double on both lower doors. Have not found anyone here to do windshield. They are afraid of cracking issues.
Reactions: SYCO GT
