Guys, I have one Ford Racing Products complete Transaxle Cooler Kit part number M-7095-GT, brand new, never installed, still in the Ford boxes. If you want to keep you FGT 100% OEM original, this is the cooler for you. The kit includes the heat exchanger, hoses/tubing, hardware, AN fittings, mounting brackets and easy installation instructions. All you need is to buy one quart of transaxle lubricant from any Ford dealer parts dept and add approx 7/8 of a quart after installation. All brackets line up perfectly with the pre-drilled and tapped frame holes and the brackets are even painted the same Argent silver to match the GT's underhood frame and struts. These brackets also include vibration dampers for added protection of the heat exchanger, tubing and AN fittings. The heat exchanger is beautifully welded and has a natural aluminum finish. It has been reported on this Forum that Ford would have shipped our cars with this exact system installed had it not been for Federal weight classification concerns and cost reasons.
I am willing to let this go to a fellow Forum Member for $1,025. which is 20% or $254.00 under The $1,279.00 that FRP charges. You will also avoid paying any sales tax.
PM me if interested as it's first come first serve and I only have ONE kit. You can pick it up if you're located near Massachusetts, or I'll ship it to you for whatever the actual UPS Ground charges are. usmcfred
