Windshield Washer Problem
DUROC
57
Westchester, NY
At about 450 miles, I discovered my first problem. Windshield washer doesn't work. I made sure it was filled with fluid. I hear the pump when I push the button but no fluid squirts out. Has anyone else had this one? Any advice much appreciated.
iTS A SHOT BUT OPEN YOUR FRONT HOOD OR TRUNK,CHECK THAT THE TRUNK LINER ON THE TOP, ISNT LAPPED OVER THE LITTLE FLUID LINE, WHEN YOU CHARGE THE BATTERY OR REMOVE THE TRUNK LINER FOR SOME REASON,SOME TIMES THE RUBBER HOSE GETS PINCHED UNDER THE LINER, UP TOP IN FRONT OF THE DRIVERS WINDSHIELD. WHEN YOU REINSTALL THE LINER AND TWIST THOSE 5 PLASTIC HOLD DOWNS. ITS WORTH THE SHOT? :thumbsup GTJOEY
Maybe the pump needs priming? Try a syringe.
Thanks to both of you. I won't be near my car for a while but I'll try what you say when I get back to it.
