Transmission oil cooler
ultrasportracing
490
Perth Western Australia
Can anyone provide a schematic of the oil flow to and from the trans oil cooler, need to know which way the oil flows.. Cheers
4,211
There are two different coolers available. The ford cooler I believe is top in bottom out while the Cooltech is bottom in, top out. Reach out and PM Nota4re (Kendall) who engineered and sells the Cooltech unit
ultrasportracing
490
Thanks, but I am more interested in which way the oil flows from the transaxle,, Does the oil come from the rear fitting on the trans through the cooler and then to the front fitting on the trans or vise versa.
Out of the transaxle at the rear-most fitting and the fitting toward the front is the return.
ultrasportracing
490
Oct 15, 2014
16
does anybody know whats the recommended oil capacity after fitting a cooltech trans cooler? i have no instructions with my kit, purchased from a third party.
The extra volume from the Setrab heat exchanger and the lines is 0.75 quarts. If installed correctly, the top line at the heat exchanger should go to the front-most port on the transaxle (the return line). As such, you can remove this line at the heat exchanger, hold it up as high as possible and then slowly pour in .75 quarts of transaxle fluid.
Oct 15, 2014
16
Thanks, confirmed that's the way I have it connected. Nice kit. Perfect fit.
