I'm not what is causing this. Obviously a problem with the coils but it didn't surface before the mile. I noticed yesterday on a hard pull that the car went flat in 4th gear. I reproduced the problem, looking closely at the gauges. Here is what I noticed at the point or just after the engine seemed to go flat:
RPMs: 5000-5300
Boost: 20lbs
Eng temp: 178, thermostat trip setting
Outside temp: 55 F
A/F reading: 18.5 max dial reading
The car was not running lean prior to this problem and did not run lean on the way home. Today I re-tested the car to see if it continued to do this. It did, but I also got some engine codes this time.
Via the SCT tuner:
P0351 IG COL A
PE SEC CIR ER
P0353 IG COL C
PE SEC CIR ER
P0354 IG COL D
PE SEC CIR ER
P0355 IG COL E
PE SEC CIR ER
P0356 IG COL F
PE SEC CIR ER
P0356 IG COL G
PE SEC CIR ER
P0357 IG COL H
PE SEC CIR ER
Thoughts?
RPMs: 5000-5300
Boost: 20lbs
Outside temp: 55 F
Via the SCT tuner:
P0351 IG COL A
PE SEC CIR ER
P0353 IG COL C
PE SEC CIR ER
P0354 IG COL D
PE SEC CIR ER
P0355 IG COL E
PE SEC CIR ER
P0356 IG COL F
PE SEC CIR ER
P0356 IG COL G
PE SEC CIR ER
P0357 IG COL H
PE SEC CIR ER
Thoughts?
