Hello Forum,
After driving I noticed a very small amount of oil by a hose that connects to my drives side valve cover (see picture below). I thought it may be the bolt and when I tried to tighten it, the bolt would not tighten and I was able to pull it out by pulling straight up on it. The bolt had some metal in the threads, so I am not sure if the hole is stripped. I tightened the other bolt and it worked as it should.
Not sure what to do with lose bolt. Any suggestions? Is there a gasket that goes between the valve cover and the metal plate?
Thanks for all your help.
