I'm trying to understand a problem on a local GT. The car is a low milage, pulley tune car with stock exhaust. It will not pass the state inspection but it doesn't show any codes on the SCT handheld unit. The state's inspection machine is the type that would require OBDII port to be attached while the car turns a dyne wheel (it's hard one to fake out). Also, the actual state inspection machine show that the Evap/Emission test is failing. All other XXXX/Emission codes are showing a pass.
I suspect the "75 mile emissions test" is the problem but I thought it would throw a code on the SCT. Any thoughts from the group?
