I have the Airlift coolant vacuum device, and was testing it to suck out the air pockets in coolant system.
I noticed my 4 Gal air compressor does not seem to have enough "gas" to achieve the required venturi vacuum.
i can only get to 10-15 on the meter which is not enough to compress the hoses.
I have a 4 Gal, rated at 5.5 CFM @ 90psi compressor.
Can those of you that have successfully used the Airlift kit please post the specs on the air compressor you used that works with the kit.
I need to buy a new compressor anyways, just didn't want to buy it twice.
thanks
thanks
