- Aug 25, 2006
- 4,436
I had same fuel smell for 15 minutes with a multi click fill up. Just filled up today with 1 click and absolutely no smell.
Good data
If ever you have the reason to remove the passenger side inner fender liner you will see the over flow hose and as another shared it can be moved or IMO better yet extended below the belly pan so that any fuel over flow would drain on the ground and not within the cavity.
Thank you
