Front turn signal lamp
SRG.GT
work hard--play hard
Mar 12, 2009
25
Hudson, Wi.
I sure could use some help in getting access to the passenger side, front turn signal lamp for replacement. Thanks in advance.
Steve
You need to remove the wheel and the inner fender liner
PM me and I will answer any questions.
as the "shadowman" states - easy when you get the wheel and liner off.
BE SURE to get a FORD bulb - not a "...auto x" replacement from your local parts shop as the color and depth of the bulb when lit could/ will. be different!
- tip from Doc Frank! and true :cheers
interesting, mine went out too.
That was my guess. I already removed the bottom cover and the driver side is easy to reach up into to get to the bulb(not the case on the passenger side.). I will pm you.
Good point. I will "test light" before reassembly
Bulb#
My pass stoped too,but whats got me is once in a wile it works for a few secs
hope its just the bulb? Yea if someone knows a part#4 bulb that would be great,i will stock some.
When mine started to go, it did the same thing...off and on for about 2 weeks then out. I just went to the local auto parts store (Checker) and they had the bulb in stock. I do not notice any difference in color or brightness.
