After months of testing the Spectacular Whipple 4 Litre soopercharger:thumbsup, we have learned quite a few things. I know some of the other guy's are wanting to improve the air box problem but they said that it would be at least a year out. I took it upon myself to modify the stock air box, it dose not look the prettiest but it is fully functional. The first problem with the box is the out going plenum on top. It's not large enough to feed the throtal body and blower. I carefully cut out the existing plenum and replaced it with a larger diameter oval tube. I also cut back the rubber bellows and the Accufab incert. This now allows proper flow with no funnel efect.
After increasing the plenum sise It was obious that now it needed more clean air. As you can see from the pictures I have stratigicly placed 4 snorkle tubes. Two that feed from the vents in the clam shell and two that feed from tubing from the side scoupes. This has doubbled the clean air to the box. "If you are not good with precise fabrication do not try this yourself"
Some guy's said " just put a big K&N cone on the back of the bellows". This won't work because you would be then pulling in dirty hot air off of the engine, since there is not much circulation when the clam shell is closed. You would end up with hotter down stream air and over heat sooner.
I did these mods out of desperation, I did not want to wate till someone re built the air box. Along with the box mods we have come up with 15 other modifications, some more significant than others. What we did achieve is 890 Rear Wheel Horse Power and 846 LBS or torque on 105 race fuel:cheers. We truly believe with some more development 1000 RWHP is not out of the question for the 4.0 Litre Whipple. "Rockstar" Rich Barnes at The Mustang Ranch in Golden, Colorado 303-931-5412 P.S. The tires spin in first, second and part or third geer!:willy
