Dead Battery, stuck window
khalid0
15
Dubai
My battery completely died, tried to open the door with manual latch in the trunk, the door popped but the window still up and stuck won’t allow to open the door, Any thoughts? Thanks
ch_petrolhead
Active member
Aug 20, 2016
29
Swiss Mountains
Maybe take a look at this ;)
khalid0
15
Dubai
Thank you for the video, actually the ford workshop boys came and did the exact same thing, so the question is did ford forget about the window dropping when battery is down?
Warned several times during delivery about keeping battery charged. Since mine is a 19 I use trunk charging port and always check the connection of the plug in. If not pushed firmly in port it will nor charge properly but will be indicated on charger lights.
Simon
938
I had this same issue. I thought it was charging but it was not fully seated.
lc2006
112
Centreville, Delaware
Bernardo Martinez gave me an excellent tip during delivery of L0054. He told me that, when parking my GT in my garage, it is not a bad idea to leave the driver's side window cracked open a fraction of an inch... just in case the battery should ever go dead.
JWZ
575
West Texas
Bernardo gave me the same advice during delivery of J105. Great guy! Full of information. He also mentioned how this was determined........At any rate: when parking new GTs for extended timeline its best to leave one of windows cracked for mechanical access should battery die. There is a process for accessing dead battery but will leave that for Italianjoe to splain.
Do you know if the trunk charging port is a direct circuit to the battery?
Iconic GT
576
Follow this thread!
Hope it helps!!!
Bakaz
5
Take the right front wheel off and the inner guard
the battery is located under the right hand head light it then give it some power you'll need to be careful there is very little room
I plan to leave my window down 1.0 inch.
BUT HOW ABOUT a charging port that is fully accessible from outside the vehicle without having to open ANYTHING. ??
Near front row hook or somewhere?
Andy (ajb)
Tow hook
@soroush did exactly that. He has a magnetic power connection that he installed in the inner fender. Added bonus, it will also break loose, when you pull out of the garage, and forget to disconnect.
Andy (ajb)
