Chrome door sills
05 Ford GT
257
Excelsior Springs Mo.
My 05 FGT has some scuffing on the chrome as you enter the car on the door jam. Has anyone found a way to polish them back up without making this issue worse? Looking for ideas!
Mike
I think they are polished stainless steel. They are glued down and cannot be removed without damage. You could try polishing them in place buy may do damage to the surrounding area, or make them look even worse.
New ones are available from any Dealer or Torrie.
I use a metal polish for stainless and polished aluminum.
Use an applicator that's soft, not terry cloth. Diaper or micro fiber for application and wipe down.
SteveA
GT Owner/B.O.D
3,694
Sandpoint Id
I applied some blue tape around the areas I didn't want to buff, then used a Dremel Tool with and some stainless polish. My results were about a 9 on a 1 to 10. However then went out and purchased 2 additional spare sets just in case.:thumbsup
Shadowman Clearbra'd my new ones when the rest of the car was done. Now it is just a peel and reapply.
That is what I did to my originals also. I then bought a set from 321 but they look too nice to put down. Here they are sitting in place but not applied. For now they are in my garage display case.
Damn, those do look good.
NJF
I just left the factory tape on mine when it was delivered new to me. While it has a blue tint and sonewhat opaque it protects from the scuffs. I would think the same would hold true for clear bra on them.
05 Ford GT
257
Myyellowc5,
Those look great. Very sharp!
Mike
I clear filmed mine.
+1
steved57
1,941
kilgore tx
I left the factory tape on mine but when it finally started showing some wear I pulled it off and cannot get the stain off from the glue from the tape
RPM217
2005 white/blue stripe
Jun 18, 2010
1,658
Rye Brook, New York
Did you try WD40?
steved57
1,941
kilgore tx
Yep, WD40, B12, Goo Off. Its not sticky residue its like a stain
GT35065
I left my factory tape on thinking what a great way to protect the sill. Big mistake. About six months ago they were peeling at the corners so I thought I'd just pull it off and put some clear film on them. What a night mare. Left that glue residue others are talking about and it took me about four hours to clean them up. I think I used goo be gone or something like that. Then I used a polish that I have been using for years that I get from performanceunlimited.com. Think the guys name is Randall Thomas and it is the best metal polish I have found. No affiliation. Mine did have the discoloration that steved57 mentioned, but it came out. They look like mirrors now.
steved57
1,941
kilgore tx
Thanks for the info as I will give this a try
This stuff?
http://performanceunlimited.com/cobravalley_chemicals/metalpolish.html
GT35065
Yup, that's the stuff. I've been using it for years now and have not found anything that works as well. You have to shake it before using, and it seems to separate more as it ages, but still seems to work well. I use it with a micro fiber towel when working on shiny stainless. Only thing it does not seem to work as well on is brass. Had better luck with Brasso for that. Worked really well on aluminum and stainless.
Cheers. Thanks
