Battery Connection Anti-Corrosion Gel and Other Connections Too
HighHP
434
Spokane, WA
Here is a great electrical connection corrosion inhibitor. It's made for electrical connections and is commonly used on your house wiring on aluminum electric conductor wire connections. Aluminum is a great flexible electrical conductor, but it can corrode so this is used to inhibit corrosion. This works great on all electrical connections including the battery post and that pesky GT battery ground to aluminum frame connection. Must be clean to start with. I have found this to be the best, due to it's consistency. Some are too runny. The generic urban term for this is "Cool-Aid".
Gardner Bender OX-400 (4 Ounce), OX-800 (8 ounce). It contains zinc which is a common corrosion inhibitor, such as zinc coated (galvanized) steel and zinc-chromate paint primer commonly used on aluminum. Read more tech specs below. The link may look weird, but it works????
Reactions: canibl
centerpunch
ex-GT owner x2
952
OH/NC
Amazon link
canibl
445
Sacramento, Cali
thank you
HighHP
434
Spokane, WA
Amazon Link 4 Oz Tube
