Nobody wants any metal particles floating around in their oil. The new Accufab Ford GT Magnetic Drain Plugs are cad plated forgings that feature an extended magnetic tip, increasing the surface area (picks up more paperclips that way). These trick pieces also feature pre-formed O-rings for a drip proof seal.
These magnets are so powerful that they will suck the nickles and dimes out of your pockets, out the window, through the air filter and right down into the bottom of your oil pan where the coins will remain firmly attached to the drain plugs.
OK, I'm lying about that part.
The complete set of three Accufab Ford GT Magnetic Drain Plugs (two for the crank case and one for the oil tank) are yours for $99.99. In stock now, (909) 930-1751.
