2100 HP Ford GT Owner Interview (Going For 300 MPH)
FordGTGuy
636
Norfolk, VA
http://www.youtube.com/watch?v=-iJOkwmno2c
Sorry if this is a repost but the first i've seen of it. Very impressive i'm wondering if the car would be able to really pull off 300 mph. I'm also wondering what the car will do with these larger turbos its some exciting stuff.
Also 3/4 of a million dollars in a car man this guy loves his Ford GT and i'm sure glad he does :thumbsup.
Kirby Vieira
GT Owner/B.o.D
Atlanta
That interview sounds very similar to one he did a year ago at a Florida event.
Has anyone on the Forum ever met or had dealings with him. There's something about him that would keep me from being the 1st...or 2nd...or 3rd... :cheers
There was a discussion on The 'Forum about this fellow & his car a while back. 'General consensus was , 'HUH?'
You're pbly right about him loving his GTs though!
I saw an older video with the same guy before. An interesting note is that he modified the transaxle to have closer ratios and strait cut gears without syncros. Too bad he isn't bringing his car to Rally IV and the TX mile. That's where the talking stops and the rubber meets the road.
Button
202
Iowa
I saw this awhile back. There seems to be a lot of red flags here? Does anyone else feel the same?
I've always wondered what aerodynamic changes would be necessary to keep a FGT on the ground & stable at 300 mph...and where the actual "brick wall" may be. :willy:willy:willy
300 mph would take over 2000HP! Assuming the car would be stable at 300, I doubt that the engine would be able to sustain that power level long enough to reach 300 mph without damage or heat soak would shut it down. That said, it sounds like it would do very well in the mile.
I believe most here have seen this video, last time I saw something on this car it dyno'd somewhere around 720, but have not seen anything new on it.
gtinmyblood
735
Mesa Az/Aspen Co
I respectfully remain ever the skeptic on this guy.
you are in the majority!
Would he have enough fuel? I remember the Veyron coming back with less than 1/4 tank after it's high speed run.
Mullet
2,468
at full speed the Veyron runs out of fuel in 10-12 minutes from a full tank. Tires are rated to last 15 minutes.
