2018–Coolant leak
GTdrummer
2,104
Richmond Virginia
Anyone else had a coolant leak on a NGT? If so, cause? Thanks
Reactions: roketman
italianjoe
180
Dearborn Heights Mi.
Is it in the front of the car or in the rear ?
I have had a coolant smell from the engine bay, took it in, no problem found.
GTdrummer
2,104
Richmond Virginia
It is left rear—puddle on floor. Thanks
FlagstaffGT
Twice. Stress point at mounting of the radiator was redesigned for cars following the realization of what was occurring. Looking down in the front could see little spots of fluid on passenger side. Was part of the three year warranty work, but now I’m just covered with Ford’s one year after doing the work guaranty.
Reactions: italianjoe
GTdrummer
2,104
Richmond Virginia
Here is the puddle. Dark part. Thoughts? Thanks
italianjoe
180
I have seen a few leak in that area.....the inlet radiator hose on the driver side has a bleed screw that leaks.......had to replace a few radiator hose because of it. If you dont mind me asking .....what dealership did you take it to ?
Joe
GTdrummer
2,104
Richmond Virginia
It has not gone yet. My nearest NGT tech is in Gaithersburg Md—Sheehy Ford
italianjoe
180
I know most of the Ford GT tech's in the U.S. and Canada but don't know the Tech at that Dealership........let me find out if one of the other GT techs know who he is......
Joe
GTdrummer
2,104
Richmond Virginia
His name is Courtney—good guy .
italianjoe
180
That's right I do know Courtney Myles good guy just talk to him he will be calling you soon on when he will be out to pick up your car.....your in good hands Sir.
Joe
For me it was the clutch cooler itself (located behind left rear wheel). Not the lines. Easy fix.
