2005 Oil Pressure gauge stopped working
TomFord GT
Feb 20, 2019
6
Georgia
Engine runs perfectly. Just was curious as to where to start looking or if anyone else has experienced this? Car has 14000 miles Many thanks
Howard
1,136
Florida/North Jersey
Not an uncommon fault. Likely it's the sender. Cheap and easy to install.
TomFord GT
Feb 20, 2019
6
Georgia
great thanks !!
68Rcodeman
800
Spring Hill, FL.
Make sure the oil pump drive belt is on.
About the scariest one to loose.
I installed the new Autometer gauges, so far so good. Knock on Wood.
I would do them all at once.
Ironically, my GT had gauge issues today too... I’ve never had a problem before, but noticed ALL of them were dead. I pulled over, turned the car off and back on and all gauges worked correctly. Does anyone have a diagnosis for this issue?
Check the battery ground, and don't just wiggle and tighten. Undo it, sand the hole and tighten. Next, replace your battery.
ENZO BTR
1,048
The battery charge state can cause the gauges to all (apparently) die. But sometimes they will do that even with the battery charged. A full engine cycle on and off usually fixes it.
Reactions: Special K
CampoLady
69
Where is the sender located. Ours stopped working also.
TomFord GT
Feb 20, 2019
6
Georgia
I will let you know when i get it......part is on order Thanks
Accessed from the bottom, once second belly pan is removed. Not a difficult change, I did it as a 1st step before going Speedhut.
