+ Reply to Thread
Results 1 to 3 of 3
Thread: oil leak, whats involved in the fix?
  1. #1
    GT Owner peiserg is on a distinguished road
    Join Date
    Aug 2010
    Location
    Phoenix, az
    Posts
    171
    Default oil leak, whats involved in the fix?
    When I had my 3.4 whipple installed by cooltech, an oil leak was noted on my belly pan. that was maybe 2000 miles ago. I have yet to see a single drop on the floor of my garage, but noted some seepage through one of the torx bolts holding the pan on.
    I pulled the pan, and i beleive (though not certain) that it is leaking from the bottom of the driver's side of the transmission
    what would be involved labor and $ wise for the fix? This is most definitely beyond my tools and abilities, so am merely looking to know if I'm getting hosed on a labor or price quote when i take it in. Alternatively, is this something I could have fixed at my house (I do have a 4 post lift with drive-on ramps) by Rich Rovack or an equally skilled Gt tech? There is a reputable place about an hour away.
  2. #2
    gt owner & supporting vendor nota4re has a reputation beyond repute nota4re has a reputation beyond repute nota4re has a reputation beyond repute nota4re has a reputation beyond repute nota4re has a reputation beyond repute nota4re has a reputation beyond repute nota4re has a reputation beyond repute nota4re has a reputation beyond repute nota4re has a reputation beyond repute nota4re has a reputation beyond repute nota4re has a reputation beyond repute
    Join Date
    Feb 2006
    Posts
    2,568
    Default
    Thats an unlikely leak place. Get a flashlight and try to check the top of the semi-circle heat shield under the half-shaft. See if there's any oil on top - or if it is dry. If the axle bolt upgrade kit was not done with the TSB for the oil leak in mind, this could be where the oil is coming from. Let's hope so. It is a comparatively easy fix.
    Go to www.cooltechllc.com to see some "cool" GT products!
  3. #3
    Join Date
    Aug 2010
    Location
    Phoenix, az
    Posts
    171
    Default
    I just degreased it, and will drive a little more, hopefully tease it out. I do have a 2ft flexible fiberoptic scope to assist.
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
