Evans Coolant
DeMopuar
Active member
May 30, 2008
29
Wisconsin
Does anyone have firsthand knowledge of Evans waterless coolant in their car? Wondering if it would work in the engine and/ or intercooler systems of the car? I know that drag racers and motorcycle racers use this stuff, but I wonder about the "real" world application on a street car.
http://www.evanscooling.com/main21.htm
Thanks,
Mark
CJ428
Farm GT
1,473
NJ
I have bin thinking about trying it in the GT for awhile now.Think I mite put it in my diesel truck first to see if it runs any cooler.
DRIVEBY
253
Las Vegas
I've been using Evans NPG+ for 2 years on both the track & street and it gives me a noticable cooling improvement. :thumbsup
DeMopuar
Active member
May 30, 2008
29
Wisconsin
DRIVEBY,
Did you only put it in the engine circuit, or did you also use it for the intercooler?
Thanks for the information.
Mark
Got it in both!
Yukonranger
118
Sagle, ID
I have run propylene glycol in cars before. You can expect higher coolant temperatures but your peak metal temperatures will be lower since it will be less likely to boil when cooling the hottest parts of the engine (the heads around the exhaust valves). You will also have more boil-over protection.
The only way you are going to get a meaningful cooling improvement in your GT is to get more air to flow THROUGH the radiator instead of around it. There are big gaps around the radiator. Someone will eventually fabricate some baffling to fix the issue.
FB GT40
GT Owner/B.o.D
812
Folly Beach, SC
Evans
I have used Evans in my race cars from time to time. The system is flushed regularly. Cooled an additional 10 degrees or so in summer heat.
MR2Race
FGT The Velvet Hammer
Apr 6, 2006
304
Northville Mi.
Yukonranger
You are spot on target.
PG will delay a failure if there hot spots inside a cooling passage casting.
But will not lower operating temps over any other coolant.
You are also !00% on track with the air flow problem / description.
PG can not help this kind of problem.
Actually straight PG was the coolant of choice at the turn of the last century.
For cold weather engine usage. (We have learned a lot in the last 100 years).
Now if you reverse the coolant flow in your race car.
Cold PG into the heads & out @ the block.
And install an adjustable thermostat.
And force normal operating temps upwards of 240 deg.
And then develop a new cals to work in this range.
There may be engine efficiency gains with PG.
But with a low speed air flow problem like the GT has on track.
There will be no gain with PG .
If there was any real improvement Ford (and all others) would have never stopped using PG. It is also less expensive than EG?
richardhead
169
Doug Rippie tried reverse coolant flowing on an early ZR-1 at LeMans, and it was a disaster. The engine and system had to be designed for reverse cooling from the get-go, it was determined after consulting with the "real" design engineers. Motors not designed with this flow direction in mind may have many unforeseeen issues develop if you do reverse their coolant flow. If this has proven to work OK with reliability on the GT, so be it. I'd be careful, however.
Luke Warmwater
Permanent Vacation
Jul 29, 2009
1,414
Boondocks, Colorado
I don't agree. My car ran 210 in traffic all the time until I had Shadowman purge the cooling system. He also put a different tune in it as well as turned on one of the fans earlier. It runs 185 all day no matter what. I have never tracked the car which might put additional strain on the system and expose some weaknesses but from my perspective, it has been flawless on the road no matter the ambient temps or traffic.
Shadowman purged your system of air bubbles and turned the fans on earlier, that is why it runs cooler.
Luke Warmwater
Permanent Vacation
Jul 29, 2009
1,414
Boondocks, Colorado
Thanks for repeating what i said. My response was to the assertion that the only way to improve cooling was to close the gaps around the radiator. While that surely would offer an improvement it is not the only way to get a handle on a hot running GT. I have run Evans in a 700hp diesel application that was having boiling issues due to a high elevation 10,000'+ running environment over some Colorado mountain passes. It was very effective.
Yukonranger
118
Sagle, ID
Not sure what you are trying to say. If your cooling system is improperly filled then filling it by removing the air bubbles will help. The point is that changing the coolant with a PG coolant WILL NOT reduce temperatures at the guage. It is also a fundemental fact that the more effective that a coolant is at removing heat from the engine, the higher the temperature of the coolant will be.
Luke Warmwater
Permanent Vacation
Jul 29, 2009
1,414
Boondocks, Colorado
I agree. In fact my coolant temps ran a little higher when I ran the Evans product which confirms that it was more effective based on your assertion correct? I didn't run it to manage coolant temps, I ran it to manage boil point issues at high elevation. Bottom line... if the OP is having cooling system issues, simply purging the air from the system and turning on a fan a little sooner will most likely offer him a very satisfactory solution.
Yukonranger
118
Sagle, ID
Sounds like we are on the same page. I used PG in a race car a long time ago and it seemed to reduce detonation which I attibuted to a reductiion of peak temperatures around the exhaust valves.
You don't have to have the fans reprogrammed, just turn on the AC.
