+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Cold Tires, Cold outdoor temps, and being careful
  1. #11
    GT Owner/ B.o.D Ed Sims is on a distinguished road Ed Sims's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    2,419
    Default temperatures & driving
    I drive at all temps with no problems. I did learn to drive in Alaska so I guess I have the experience. I've ridden motorcycles on the street in below zero temps so driving my GT in sub-50 temps is no problem. Like DBK says - less aggressiveness is the answer.
    GT Owner/ B.o.D roketman is on a distinguished road roketman's Avatar
    Join Date
    Oct 2005
    Location
    Posts
    2,846
    Default
    Softer compound tires will warm up quicker .ie Hoosiers .Also bumping up tire pressures 5-lbs will make the tires heat up faster .Be careful not to over inflate .
  3. #13
    GT Owner MDT is on a distinguished road
    Join Date
    Jun 2006
    Posts
    181
    Default
    The tires themselves are the most important. Once a tire has too many heat cycles, it will not have grip. Does not matter how much tread is left. This of course only affects high performance tires, but that should be what is on this car. Of course, high performance tires are often called "summer" tires for a reason.
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
