+ Reply to Thread
Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 50
Thread: Loss of 3rd gear
  1. #31
    GT Owner/Vendor tmcphail is on a distinguished road tmcphail's Avatar
    Join Date
    Apr 2006
    Location
    St Augustine, Florida
    Posts
    3,755
    Default
    Excellent to hear !
    Take Care,
    Torrie R. McPhail
    www.FastPartsNetwork.com OEM Ford GT Parts Specialist
    www.UnleashedTuning.com Ford/GM/Dodge SCT Custom Calibrator
    2005 Black Twin Turbo Ford GT 221.7 in the Miami Mile
  2. #32
    Ford Gt Owner soroush is on a distinguished road soroush's Avatar
    Join Date
    Aug 2007
    Posts
    3,543
    Default
    good luck!
  3. #33
    Red Whipple Yellow TT TEXAS GT is on a distinguished road TEXAS GT's Avatar
    Join Date
    Oct 2005
    Location
    EAST TEXAS
    Posts
    1,513
    Default
    Quote Originally Posted by Cyclenirvana View Post
    But I am the most bummed about the trailering instance. I keep thinking about what I could have done differently?? Perhaps had the winch tighter, but I had been told not to do that. Emergency brake was on...car was out of gear. Oh well.
    Install e-track and use straps that go over the tires. Even if one fails, the other 3 won't let it budge.
    Never tighten your winch but leave it attached loosely.
    Leave e-brake off. Tranny out of gear.
    If you wear suspenders and a belt, you could even use your present method of strapping in addition to all this for peace of mind. You can never have too many straps.
    Drive it like you stole it!!
    223.007 MPH @ THE TEXAS MILE 03/28/2009
  4. #34
    GT Owner/ B.o.D Cyclenirvana is on a distinguished road Cyclenirvana's Avatar
    Join Date
    Feb 2006
    Location
    Winston-Salem, NC
    Posts
    595
    Default
    Quote Originally Posted by TEXAS GT View Post
    Thanks for the advice. I had an aftermarket ramp installed in my trailer that allows for easy entry and exit as well as the driver door easily clearing the base board of the trailer side door. The downside is that the rear tires sit lower than the front tires (on the slope of the ramp) meaning that the straps I use on the front tires are really what's keeping the car from moving backwards. I have a front stop built into the ramp to keep the car from moving forward. The straps have a hook that grab onto D-rings on the floor. I generally don't use a winch, but for some reason I decided to use one that day, albeit loosely. Had I used some closed hook system rather than a simple open hook I think nothing would have happened. But I would like to try something that would literally keep those front tires from moving at all, no matter what, and something that could not get bounced loose (or off). Tire baskets or straps that go over the tires sounds like a great idea!
    ""It is by riding a bicycle that you learn the contours of a country best, since you have to sweat up the hills and coast down them."
    Ernest Hemingway
  5. #35
    ex-GT Owner/ B.o.D Empty Pockets has a reputation beyond repute Empty Pockets has a reputation beyond repute Empty Pockets has a reputation beyond repute Empty Pockets has a reputation beyond repute Empty Pockets has a reputation beyond repute Empty Pockets has a reputation beyond repute Empty Pockets has a reputation beyond repute Empty Pockets has a reputation beyond repute Empty Pockets has a reputation beyond repute Empty Pockets has a reputation beyond repute Empty Pockets has a reputation beyond repute
    Join Date
    Oct 2006
    Location
    Posts
    13,497
    Default
    What about constructing a set of wheel chalks that bolt/screw to the floor?
    For instance, you could put two aft of the front wheels and two fwd of the rear wheels, and nuthin' would go 'nowhere'... or just put a pair of chalks both forward and aft of each rear wheel (since they'd be a lot easier to get to)?
    You'd still wanna use straps as well, of course.
    Just for info: the factory sez to use tire baskets. So, Ya! It's a good ideeee!
    "I intend to live forever... So far, so good." (Steven Wright)
  6. #36
    Spectator MrFORDGT is on a distinguished road
    Join Date
    Nov 2008
    Posts
    3
    Default
    Please Help! I was driving along in 6th when I lost all drive to gears, this happened before so I assumed it was the drive shaft bolt again, no big deal, the car was recovered to Roush and now they tell me that the gear box has gone!, straingely they were able to get 1,2nd?! I just dont understand it:[
    does anyone know where I can get a replacement gearbox?
    thanks guys n girls.
  7. #37
    Join Date
    Oct 2006
    Location
    Posts
    13,497
    Default
    Quote Originally Posted by MrFORDGT View Post
    'Simple answer: If the car is still under warranty - contact your dealer and they'll take care of it. If not, contact Ricardo directly and have 'em send you one. Or, you might call one of the 'Forum sponsors who deals in such matters. (Roush should be able to handle it...and your car's already there.)
  8. #38
    THEE GT OWNER tpraceman has a reputation beyond repute tpraceman has a reputation beyond repute tpraceman has a reputation beyond repute tpraceman has a reputation beyond repute tpraceman has a reputation beyond repute tpraceman has a reputation beyond repute tpraceman has a reputation beyond repute tpraceman has a reputation beyond repute tpraceman has a reputation beyond repute tpraceman has a reputation beyond repute tpraceman has a reputation beyond repute tpraceman's Avatar
    Join Date
    Feb 2006
    Location
    Washington Michigan
    Posts
    2,253
    Default
    Ditto on everything except for the tire nets. I have had bad experiences with tires loosing air while trilering....But many use them with no problems.
    If in gear and then you tighten straps you might be applying a load against the trans while hitting the brakes and bumps more manual trans have been hurt than not.
    My first time with a dragster I learned the hard way about an air donut in the middle of the car to support the frame........bent the car in two.......While all the guys came by and said what you didn't have a air bladder under it
    Also do not cross strap ever. If one lets loose the car will be pulled/hop into the side of the trailer....not good.
    What ever it is...it's just got to go faster
  9. #39
    Join Date
    Feb 2006
    Location
    Winston-Salem, NC
    Posts
    595
    Default
    Ford is covering the transmission!!! Yahhoooo! Will get a new transmission. After that's done, it is off to the GTguys for the new rear fascia and a few goodies!!
    hmmmm....time for a pulley and tune orrrr Whipple?????
    Ernest Hemingway
  10. #40
    GT Owner Hammer is on a distinguished road
    Join Date
    Sep 2006
    Location
    San Diego, CA
    Posts
    218
    Default
    That's great news, Cycle! And good on Ford for stepping up. All I can say is, whatever you do with the GT Guys, you're going to love it. I had a recent pulley/tune, short throw shifter, tranny cooler, and Borla installed by them, and I couldn't be happier!
+ Reply to Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
