Rear firewall glass replacement and
RaceDeck
*Supporting Vendor & GT Owner*
267
SLC Utah
So after a great morning canyon cruise, I was washing my FGT and noticed that the flat glass on the rear fireweall has a hairline crack across it..Bummer! not sure when it happened because you can only see it under various angles and light. Has anyone had one of these replaced?
Also on my steering wheel horn pad, the silver Ford emblem has become cloudy ( guessing the clear coat on it) is this an easy part replacement or is it a full assembly?
thanks for any insight . :)
It seems that the folks at the last rally had a lot of problems with the firewall glass cracking. Must have been some secret Russian weapon that cracked all of them at the same time. Noone ever found a cause. Altitude cannot cause it since there is no pressure differential between the engine and passenger compartment.
As far as the steering wheel badge goes, Shelby at Elite Autos can replace it for you. You'll have to remove the steering wheel assembly. Can Shelby replace or cause to have replaced under official Ford record keeping the driver side air bag inflator? (So that NHTSA requirements so that it gets into OASIS). If so it would be a good time to have both done.
Nafod
A few people had rear inner window issues arriving/during or after the last Rally in SLC. Don't think there was ever a known/common cause.
Rich Brooks has seen these and may have some ideas for the cause.
The center emblem has been a issue for a while. People have turned to Shelby Smith who has a fix, so you don't have to replace the whole center unit.
Think it involves removing the cover, sending to Shelby. Few day turn around.
PILOTJPW1
Maryland
Wow it’s a SLC phenomenon. Some how my car missed the glass breaker. But the law caught me.
RaceDeck
267
SLC Utah
it really is strange.. maybe the huge temp swings from inside engine area to cold mountain air when windows open? Not sure when it happened, just now noticed
cleaning day :)
Jim
203
Michigan
Just curious....does insurance cover this like it does for windshield?
partssmann
755
A GT owner here ordered the replacement glass from Ford. Rich Roback removed the seats, panels, subwoofer, etc. Dropped of the car at Safelite Auto Glass to remove and replace window. Took several hours to replace glass and the guys at Safelite Glass said don't bring me another one of these to replace.
RaceDeck
267
SLC Utah
I would think its not covered by windshield insurance. At least its a flat panel of glass.
Cobraguy
You are correct.....I supplied the replacement glass to Rich (sourced from Ford) and he looked after the install as described. It was not covered by my ins policy although one or more members here who experienced the same malody at the rally did receive coverage.
Overall a real PITA situation....good luck ;)
Mine and others cracked at SLC Rally 12. it is a nice horizontal crack of the middle pane of glass. It looks like a thin antenna wire actually.
I am going to leave it in place and nicely cracked.
It is a story to tell and no one really notices it unless you tell them.
I said it happened on the "UMC Track while I was chasing Henry Ford III in his Heritage number 3... at Rally 12 :):)
It is a fond remembrance of a very nice Rally in Utah.
TACHY
490
Fort Myers, Florida
I too had the glass crack at Rally 12. Did get Ford dealer to replace but a royal PIA. The dealer had to order glass from Ford after I presented current registration documenting ownership. They did not check the glass until their "installer" arrived WEEKS later only to find the glass was cracked. Repeated this entire senario, then waited on arrival of thin gasket material (visible at the base of the glass when viewed from engine compartment). Total time at dealership was 7 weeks!! Only bright spot was insurance did cover it.
just wondering anyone look into getting the glass fixed? I thought there might be way of filling the crack and making it almost disappear.I had a crack on my 71 Camaro windshield and called up a guy and he came 30 min later you could hardly see it. Very faint line left after the fix. Might be a better solution than going through the trouble of changing the glass and it also prevents it from getting worse.
Soroush..
The crack is in the middle pane of the 3-pane sandwich of glass (Triple pane with the center one exhibiting the crack. )
SO you cannot get to it for any repair. The good news is that it does not have a sharp edge either inside the vehicle or inside the engine
compartment.
Thanks AJB,
I didn't realize that was the case and yes that would make it a PIA all around
RaceDeck
267
SLC Utah
Well that is not a cheap flat ford glass panel. 1800 installed ouch!
RaceDeck
267
SLC Utah
Would someone have Shelby Smiths contact info for that emblem part ?
PM sent
On non Ford GT related windshields, I have used those DIY window rock chip replacement kits several times, with very good results in all cases except one. But I've only used the resin for chips not long cracks. And the one that it didn't work on, was a rather large chip. It's kind of fun to do, because the results are typically quite good, and it just takes time and a hot sun to dry.
