Fan works-no hot air?
TomL
7
Glen Ellen Ca
The hot air control does not work. The fan comes on, but no heat.
Simon
1,231
I bet it is the blend door.
ultrasportracing
490
Perth Western Australia
heater
This should help.
The temperature blend door seems to get lazy, perhaps from lack of use. I wanted some heat for the first time in years and didn't get any. I cycled the control several times and after the car warmed it came back to life. Give it a try if you haven't already. Maybe you'll get lucky.
PSA:
Cycle through every a/c function and temperature setting every time you drive the car.
TomL
7
Glen Ellen Ca
Thanks everyone for responding. I cycled the heat & A/C multiple times, & all is working correctly. Thanks again!
Tomcat
Okay...hijack, I cycled through all the settings and still no heat. Cooling works GREAT! What is the next step/troubleshoot for a lazy mix door? (without taking apart the dash.
Same on mine. Cycled thru everything multiple times; no heat.
Tomcat
Is there a part number for the actuator? Is this accessible if/when I'm doing the airbags?
