TURN SIGNAL NOT WORKING
NorthwoodGT
1,215
Michigan
I'm stumped on this one. emergency flasher works on both left and right, front and rear so we know it's not a wiring issue.
Left front turn signal and rear left turn signal work fine. Right front and right rear turn signal- NOTHING. had the GEM out a couple times for other issues. a wire pulled out? multi-function switch? all worked fine before. it's not a ground or a battery issue.
suggestions?? thanks
Bad bulb?
Bad bulb?
Maybe a SmartBulb, but not a bad bulb.
Isn't there more than one filament in the turn signal bulb up front?
NorthwoodGT
1,215
Michigan
if the emergency flashers work, it's not the bulb
Scott, I havne't dug into the wiring diagrams yet, but I'm certain the turn and flasher lights are controlled through the SJB (smart junction box). They have to be, in order for the key fob to activate them when you remotely lock the car--speaking of which, when you lock the car with the fob, do the lights flash?
Then I'd look closely at the turn signal switch. These do wear or fail. Fiddle with it and see if pushing harder or forward or backward whilst engaging the turn signal makes any difference. The turn signal switch is easy to get to. Back when I first bought my car and joined the list, I wrote up a procedure for removing the cowl around the steering wheel. My tilt-wheel lever adjuster had loosened and was not holding the adjustment very well. Anyway, two or three screws hold on the cowl halves, and then you can get to the connectors and turn signal switch. You can try to jumper around the switch and see if the turn signal activates.
Next, I'd get into the wiring diagrams and see if there is a replaceable flasher for the right turn signals. Probably not, because the SJB most likely handles that function too. But the diagrams will give you the current flow and show where to check for continuity or signal and the wire color codes for jumping around the switch.
Johntpr
236
Rockland County, NY
Maybe some of the diagrams from my thread may help you? See below. My issue wound up being the SJB, but a turn signal switch being bad can also be the culprit. They are cheap enough and easy to change.
http://www.fordgtforum.com/forums/s...ide-Tail-light-Issue-comes-on-dimly-by-itself
FBA
1,663
31.022340° N / 44.846191° W
Turn signal switch; mine failed on the high beam / low beam. I'd bet big it's that.
thegtguy
*Supporting Vendor* GT Owner
Apr 20, 2006
546
MI
Im inbetween a few cars. Bring it down next week. Should be able to figure it out.
NorthwoodGT
1,215
Michigan
thank you all for your offers of help and especially Rich. I haven't been back at it in a couple weeks. 4 funerals in 10 days plus too cold (or I'm lazy) to put the heat on in the shop.
anyways, I found it. as mentioned before, the GEM module or smart junction box at the passenger floor can be a fickeled bitch my friends. I had it out to change something else and I thought I was very gentle with it. however it says casted right in the plastic of the box "scrap if dropped more than 20cm". I swear it never got dropped but maybe it got bumped and took a G load of some kind. replaced the GEM with a new one and presto, everything works.
made no sense to me because the bulb worked fine in the head lamp and the tail lamp worked when putting on the emergency flashers which is the same lighting elements for the turn signals. so I'm back in business and won't have people yelling at me when I make right turns with no signals this coming summer
GEM module huh? Wonder why it only affected the right turn signal?
CJ428
Farm GT
1,473
NJ
I would have thought it was the switch.
