Oil Cooler leak....
davidn
125
Carrollton,Texas
Noticed a small oil spot under the car and after pulling the pan i traced it to the oil cooler under the filter housing....got the gasket from ford and changed it ...No leak for the first few drives ..then today after car and coffee i looked and sure enough the leak is back .....the leak must have started on the drive home as i looked after i park at cc and it was dry........ the old gasket looked okay when i pulled it.... see pics...... any thoughts on a fix?
The usual advice: try your best to trace to where it's coming from--is it along the seam the gasket seals, or from somewhere in the cooler itself? I'd drive it without the belly pan to more easily see where it comes from.
NorthwoodGT
1,215
Michigan
are you sure it's not a coolant leak from the 2 hoses going into the cooler?
davidn
125
Carrollton,Texas
Yes sir...100% oil leak....you can see it from the top and the puddle of oil.... I know what the source of leak .....but not sure why the fix (changing the gasket) didn't last......I plan on putting on the rack again and take it all a part look.....just didn't know if this was a known issue or Isolated to my car.....
davidn
125
Carrollton,Texas
pete,
like I posted above I know the source for the leak but lost as why the fix didn't hold....thanks for the reply....:thumbsup
CanadaGT
189
Edmonton Alberta
As a Harley builder I would always use a product from Loctite called 515 gasket eliminator, Just put on a clean glove and put on fingers and just gently massage gasket with it before install. Do not need lots just a little bit. My cars and toys do not leak. Touch wood LOL A tube will last forever.
davidn
125
Carrollton,Texas
thanks for tip ..... I will give that a try after I take everything apart and inspect....for I know I didn't torque the bolts correctly.....
Early on (2006-ish) I seem to remember a couple of GT's with a cracked OEM oil cooler. I would think the gasket is fairly straightforward and you've probably got it right - but it might be the cooler itself.
davidn
125
Carrollton,Texas
Thanks.....like u said the gasket was simple.....but i didn't remove the cooler and insect on the bench....That maybe my problem....
Take the cap off of your coolant reservoir and make sure you're not getting any oil in there..... also make sure no coolant in the oil reservoir. An external-only oil leak is a best case scenario for these types of coolers. You'll want to take care of it before it allows either of these two fluids to mix.
davidn
125
Carrollton,Texas
Hope that is not the case.....that would be a bigger job for me handle ....I plan on working on it first thing tomorrow....
