Engine coolant pump replacement?
junior
1,151
So Cal
Happy to report no splatter on the fire wall glass. Will be taking the rear belly pan off over this weekend and examine the pulley below that clamps to see if there are any white colored residue on it.
So what were the results? Did you guys fix the leak completely and permanently?
junior
1,151
So Cal
After changing the culprit clamp back to the OEM one (see picture in post no. 19 in this thread), and few test drives as well, the splatter has not surfaced on the glass fire wall so far. Have not removed the belly pan yet to examine the pulley for any "dry" water deposits (see post no 8 last picture). I will do that on the next oil change.
