Rear Diffuser Panel Issues
NorthwoodGT
1,215
Michigan
Just ordered in 2 rear diffuser panels for customers and both were incomplete. the aluminum panel is there but the composite diffuser fins are not attached or even in the box. all that's coming though is a the steel panel. Hold off before ordering one until I post the update.
Thanks for the heads up Scott.
Two part numbers now?
NorthwoodGT
1,215
Michigan
No same part number just missing content. something's up because inventory on that part went from 293 pcs. in January to 3 showing in stock now.
It's possible they are making the corrections on the part (I hope)
"Hey John, did you remember to put those fin things on the belly pan?"
"Huh?"
FENZO
1,518
Lafayette, CO
Somewhere there is a pile of diffuser fins.. wish I could get my hands on those.
If you just want the fins, Stillen is the way to go. Flexible urethane is forgiving of minor bumps and scrapes. $323.
Do it yourself pop rivets won't look as good as the OEM unit, but same as if you tried to install factory fins. The Stillen fins look great.
Sent from my SM-G935V using Tapatalk
FENZO
1,518
Lafayette, CO
Thanks. Nothing technically wrong with mine other than the surface finish is diminishing. Suppose I could just have it painted.
The Grey Ghost
685
Kansas City
Replaced mine with Stillen after a mishap with a parking block.
They didn't get along well with my factory muffler before I swapped it out though.
NorthwoodGT
1,215
Michigan
Ford has now pulled all the inventory of the diffusers to hopefully do the fix. wish they would just forget it sell us the big stock pile of fins sitting somewhere! (lol)
NorthwoodGT
1,215
Michigan
Ford PACO just asked for these pictures. Hopefully the fix is on the way.
NorthwoodGT
1,215
Michigan
Current status 5-22-2017:
FILL EM-ORDS FROM: YU HCCS UPON RECEIPT
2 CAUSAL DESCRIPTN1: XZ DEMAND EXCEEDS FORECAST
3 CAUSAL DESCRIPTN2: WQ QUALITY ISSUE
4 51817 3PCS WILL BE MADE AVAILABLE AT MEMPHIS HCC BY 05/23
5 51817 SUPPLIER IS DUE TO SHIP 3PCS ON 06/06
nothing yet
Sorry to hear of the delay, but dang, those chromed standard wheels look awesome on the red rocket!
