Help with radio - macintosh
Chempowr
76
My radio does not work. It turns in but just static. Any thoughts? I checked all fuses.
if you want to make sure you can swap it out with mine to see if its the stereo or something else
Chempowr
76
Thanks! I may take you up on that. Is it an easy swap?
if you have the tool and the know how yes, if you don't it will take two hours , don't ask me how i know.
Chempowr
76
Lol. I will txt you
The tool is a standard din removal shim. I've seen them at frys and best buy
Is there a repair center for our units if we should ever need one?
That's a great question, Mcintosh is still in business, but has undergone one (maybe 2, can't remember when DM bought them) ownership changes since the GT program. heck mine might be broken, I have no idea, I never use it.
Chempowr
76
Thank you
Chempowr
76
Mines been down too since 2014 lol
Simon
1,230
I have the tool if you need to use it
NorthwoodGT
1,215
Michigan
The Ford dealer authorized radio repair company is United Radio in Pennsylvania. their number is 800-448-0944. most radio repairs at a dealer are sent to them. please post your findings with them. there are several of us who need radio repair on the forum. scott
OK here is the deal, I just called McIntosh, all of their 12v service is handled by George Meyer AV In CA
310-820-1113
http://www.georgemeyer-av.com/
From their site:
Car audio
All car audio repairs are completed at our West Jefferson Boulevard location.
George Meyer AV is the only factory authorized service center in the U.S. for McIntosh car audio equipment.
$75 car audio equipment estimate fee, which is applied to the repair cost.
See drop off and shipping details below.
TO AWSUM
Ford GT Owner
1,506
Niceville FL
Sounds to me like the radio is working and maybe just the antenna came unhooked.
Chempowr
76
That would be great! It stopped working after a bump in the road. I will look into that. Thank you.
wait is the cd player working?
you might (I'm not sure) be able to reach the back of the unit to check to see if the antenna is connected you would have to reach around the back i forget what side the antenna connection is on someone that has one out can take a look real quick
While you are there dig out the AUX input.
The first (and easiest) thing to check is the antenna lead at the windshield. Mine fell off. I re-glued it with "Permatex 21351 Electrically Conductive Rear Window Defogger Tab Adhesive."
The GT Guys say they reject a lot of new windshields, because they arrive with the antenna lead snap button detached.
analogdesigner
949
San Clemente, CA USA
The McIntosh optioned cars have an RF preamp located in the headliner near the antenna connections. I do not know if the non McIntosh (Rockford/Fosgate) cars have this preamp. It will need 12 volts to power it. I have not seen this preamp and was told about this from an engineer at McIntosh Labs that worked on the project with Ford engineers. This preamp was needed to improve radio reception. I never saw any mention of this in the service or wiring diagram manuals. Can anyone else provide info on this?
Jay
Kayvan
4,782
The radio acts up with a weak battery; especially if GT is started recently after non-use or very old battery.
I would expect no sound v. static (which I had) with a weak battery and loose ground-strap.
Put it on a the OEM trickle charger and re-tighten the battery ground-strap, before tearing it out. My radio issued cleared up in 2011 and fine ever since.
Also, note if check-engine or doors/mirrors act up with weaker battery.
